It could be a few things, but first guess would be the AOS (air oil separator). A quick check to tell if it is this is to start the engine and then remove the oil filler cap. If there is a strong vacuum when you are removing the cap, then the AOS is failing.
Search on here for AOS, Lots of info.
Dave.
2001 Boxster S.
Speed yellow.
