There may be ...
... other issues aside from the bent droplink.
Having an alignment will most likely find them and get them corrected.
The droplink only acts upon the anti swaybar but even bent a little shouldn't affect your drivability as you describe.
My guess is that your toe alignment on that side is out of spec due to the track arm's cam adjustment which moved.
Happy Boxstering,
Pedro
Racecar spelled backwards is: Racecar!
