Old 08-10-2011, 07:32 PM   #7
shlim8
sasha, did you notice that the new breather valve (the black plastic tip) actually sits alittle higher than the original old one, when it is installed ? Thereby the metal clip is alittle looser on the new valve than the old one ?? Noticed that on mine.
Anyway, to your question - on my new breather valve, the black tip is high up (sometimes to the point that I can flip the metal clip up with little tension) when the engine is hot. But with the new coolant bottle, I don't have any condensation at all.
When I had condensation after installing the new valve, it was traced to 3 hairline fractures on the top of the coolant bottle (caused when I re-installed the new breather valve because I thought something was wrong as the black tip sat abit higher than the old one It was fine after the first install).
Check your coolant bottle for cracks - mine was so fine, that almost missed them... they were like little fine scratches on the black plastic surface and partly covered by the breather valve.
shlim8 is offline   Reply With Quote
