Old 08-10-2011, 07:24 PM   #5
ppbon
ppbon's Avatar
I prefer ...
... dedicated LED Daytime Running Lights.
If you're going to run your front fogs as DRL you should change the H7 bulbs to LED because of the heat. The fogs were not designed to be run continuously so they will yellow quickly.
By installing LED bulbs which run much cooler they will remain clear much longer.
Happy Boxstering,
Pedro
Racecar spelled backwards is: Racecar!
ppbon is offline   Reply With Quote
