Old 08-09-2011, 05:28 AM   #4
Mark_T
Motor mount - no problem. The only problem I see with the water pump is getting something big enough to hold 5 gallons of coolant under the drain hole with only seven inches of clearance under the car.
I'm with you on the jack stands. I like having 17" of room under the car, but the lifting/lowering process is a pain with a real potential for disaster. I'm seriously considering a lift, probably a Max Jax Two Post Lift. Over the long term i think it will be well worth the money.
'99 black 986
