Originally Posted by tonycarreon
Kickdown
The kickdown function is active in selector lever position D, even if you temporarily change to manual mode M using the toggle switches on the steering wheel.
For optimum acceleration, e.g. when overtaking, depress the accelerator pedal beyond the full-throttle point (kickdown).
The transmission shifts down depending on the speed of travel and the engine speed.
Upward shifts occur at the highest possible engine speeds.
These gear-changing speeds remain active until the accelerator is released to approx. 80% of the wide open throttle position.
This description has got to be about the only thing that makes the Tiptronic seem fun to me...kidna wanna try it.
-O/D
IMSR + RMS
Robbins glass window top
