Originally Posted by Lil bastard
That tire has delaminated and must be thrown out. Usually a tire delaminates after a fairly severe impact with say a pothole or speedbump. It is unsafe and you will never eliminate the shimmy shakes running on it.
Also, the same impact that delam'd the tire is likely to have bent your control arm too, so have them checked to spec. Again, with bent control arms, the car will never balance or align properly.
Cheers!
Yeah, it is pretty bad. I will be getting 2 new rear tyres now. I'll have a look at the control arms..
Originally Posted by pompous
The gap there is normal. Mine looks the same.
Excellent, that helps.
Originally Posted by jakekit
Note to self. Never make a list of work you've done on a car you've owned less than 6 months.
hah! Yeah, it is crazy when you make a list. But it's good to know exactly what needs fixed, and what is priority.
I replaced the handbrake sensor yesterday and it fixed the problem! 1 thing down, 9721387 more to go.
