Old 08-07-2011, 12:00 PM   #1
rdougan
Transmission Rear Main Shaft Seal leaking, again
I replaced my clutch just under ~2k miles ago, and along with that, I replaced the rear main shaft seal in the transmission.
About 50 miles after I done that, it started leaking. So I replaced the seal again and made sure 100% that it was fitted properly.
It is now leaking transmission oil again. FML.
Is there something i put on the seal to make it stay in place? Some kind of glue/lube? And to stop it from leaking..
Thanks.
rdougan is offline   Reply With Quote
