Originally Posted by chaudanova
I recall reading about this as well, although I've heard some mention that they used Ethanol, instead of Methanol.
Do you know if it makes much of a difference between using methanol versus ethanol?
This works great for a sniffer test. Not so much for an OBD2 plug-in readiness check. Usually most people use a mix of E85 and pump gas. I had a Turbo MR2 with no cats that could pass doing this on a stock ECU.
