Old 08-04-2011, 09:39 AM   #11
idheaton
Originally Posted by Byron in Atlanta
ok...got home and hooked up the obd tester.....still no codes, or pending codes. Checked emissions and these are the two items out of eight that show " inc" (inconclusive?) cat monitor & evap system. Also checked the report from the emissions place. Just says "Readiness = Fail" , KOEO = PASS, DLC = PASS , MIL CMD = PASS
The emission printout lumps all of the systems into the one 'Readiness' category so if your reader is telling you only two systems are inconclusive which I am guessing means 'not ready', then you may be fine. Ask the emissions tech how many system you are allowed to fail and still pass the test for your MY.
Since you are in Atl, if you want to we can meet up somewhere and you can use my code reader to see if it is reporting similar system readiness as your reader. I am in Smyrna.
- ian
idheaton is offline   Reply With Quote
