Old 08-01-2011, 04:26 PM   #10
tonycarreon
tonycarreon's Avatar
2001+Tip:
so far, i'm in for $5,658.31 since may 2009, including the new GAHH top (upgrade, not required), plus around $425 in oil changes (i do my own). i bought the car with 65k miles and i've put 25K miles on it. except the alternator ($237) nothing was a complete failure requiring replacement. the strut mount ($445), motor mount ($314) and control arm ($500) were failing, but had not failed. the rest were preventative/maintenance items.
60k Mile Service
Headlight Assembly Connector
Strut Mount
Air Filter
Polyrib Belt
Coolant Cap Update
Cabin Filter
Replace Sparkplugs
Replace Fuel Filter
Replace Engine Mount
CV Boots
4 Tires
Replace Alternator
Brake System Flush
Lower Control Arm
GAHH Top
Oil Changes (x4)
prior to my ownership, the only records i have include:
15k mile service
gas cap recall
brake fluid flush
shift cable recall
30k mile service
45 mile service
mass air flow sensor
rear main seal
throttle body cleaning
along with tires, headlights, wipers and oil changes...
