Old 07-31-2011, 08:55 AM   #1
bugman
Wink
Check the idle control valve is not stuck in the closed position, if it is you will not be getting any air into the inlet manifold (other than crankcase breather) at idle, as soon as you open the throttle the butterfly valve is then open giving you the correct fuel air mixture.
Good luck
bugman is offline   Reply With Quote
