Old 07-30-2011, 06:38 PM   #1
bmx672
Need help! I almost figured out my fuel tank problem...
Okay guys, so today was the day I started to tackle the problem with fueling my Boxster (after three summers). I always thought it was the slipped tube flapper problem and didnt want to deal with it. It wasnt the problem. My filler tube is shrouded by a plastic tube in the tank and is not in contact with anything. It free flows from the filler all the way into the tank.
So, that means a vent problem...
The attached photo shows the top of the sending unit. My finger is pointing to the vent. I took the unit out and was unable to blow in or out (I know its a one way). My question is, does that mean that its bad, or are there electronics involved? Im trying to find out if this part is bad regardless if it's plugged in or not to the system. I would think that I should be able to suck air through it...
(I was able to blow through the tube attached to it on the outside by the way.)
Any help is VERY appreciated!
[IMG][/IMG]
bmx672 is offline   Reply With Quote
