Old 07-29-2011, 11:41 AM   #2
Gilles
Mike,
You may have a CV joint that became loose, check underneath and if this is the cause they are pretty simple to reattach.
Originally Posted by mikesaletnik
Hello I have an 02 Boxster with 86,000 miles. I recently drove the car to a friends house and everything was fine, when I went to leave the clutch started slipping and finally went altogether. There were no signs of a problem previous to this. No slipping, no grinding, and no smell of a burning clutch. The pedal has pressure and you can hear it going into gear when you shift it. However it just acts like it's in neutral. Any ideas? THANKS!!!
Gilles is offline   Reply With Quote
