Old 07-28-2011, 02:23 PM   #2
Burg Boxster
IIRC (it's been a while since I've done this) you pull the switch button out delicately by grabbing it on both sides. Then there is a (maybe 2) torx screws holding the switch housing in place. Remove those, disconnect and you'll be good to go. Once it's all free, make sure you use extra caution while removing as there are some VERY sharp clips/pins on the underside of the cluster which can and will easy scratch your dash. Have towels for placement at the ready.
Good luck
