Basically, should you look for a set of high quality headers that have the appropriate size tube diameters which incorporate longer equal length primaries that flow into a well design merge collector. Those shouldn't be too hard to find. High quality headers for the boxster are plentiful, and prices run the gamut . However, as far as the cats are concerned, in order to improve upon the oem set-up, you'll need to source something along the lines of HJS or Emitec 200 cell tri-metal cats. These items can be very ex$pensive ! In addition, the cats will likely be offered in "raw" form only; which means that they'll have to be fabricated into your system . There's really no inexpensive way around it .
