Old 09-02-2005, 06:17 AM   #2
valcax
Originally Posted by deliriousga
1) I don't understand what you're refering to when you say "position light is on". What's the "position light"?
2) I'm not sure if that one normally turns on when the key is turned. Open your trunks then turn the key and see if it lights up. If so, close one and check again, then do the opposite and you've tested all of the switches.
3) That's normal. Analog speedo is on left, tach (since it's most important) in the center w/ digital speedo under it, other gauges on the right (with the ever important oil pressure and voltmeter gauges missing ).
4) I don't understand that one either. Does the warning light say "CAT" on it? I don't have my manual with me to see what light you're talking about.
1) When you turn the light swith to position "1".
2) No light turns on when opening trunks, .... broken bulb?
3) Thanks.
4) Yes, light say "CAT", it is on left side to "check engine" light
valcax is offline   Reply With Quote
