Old 07-23-2011, 04:07 PM   #1
Jager
Jager's Avatar
This could be a fun one... You need to verify the electronics. Remove the trunk front panel by removing the three plastic retainers and pull back the carpet to expose the control module. How many connectors does it have? The DME 5.2.2 has a 88-pin connector and the DME 7.2 has 5 connectors (A 9-pin, B 24-pin, C 52-pin, D 40-pin, E 9-pin. I would be very surprised if someone upgraded the system to a 7.2 DME.
After changing the plugs do an AOS test by taking the oil fill cap off while the engine is running and warmed-up. Is the oil fill cap hard to take off? Does the idle drop where the motor almost dies?
Jäger
300K Mile Club
