Originally Posted by jcb986
Why do you think you have a blown head gasket...sometimes just re-torquing them solves a problem...if you have oil in the water or water in the oil you have a bigger problem.
See my earlier thread.
Is coolant supposed to be thick and gold?
The oil cooler
did need to be fixed, and the leaky coolant reservoir needed to be replaced, but it's still leaking coolant. The mechanic is down to the head gasket as the cause, so I'm trying to anticipate cost.
