I was doing a little driving on some tight lower speed turns at 4 to 5K rpm and the temp crept up to past the 0 in the 80 C (180 F for you southern folks). I havent seen that before under similar driving conditions. It is has been close to 100 F here in Toronto recently. It took a long highway drive to dissipate the heat. I get the feeling that the ultimate cooling capacity of the car is not what it should be even with the hot weather
986 00S
