			Was the battery disconnected at any time?You might need to reset your egas? Try these steps and see what happens:
 Turn car off
 Turn ignition on (Do not start) (DO NOT TOUCH THE GAS PEDAL)
 Wait about a minute (you'll hear the throttle motor run in the engine compartment)
 Turn key off (remove key) wait for at least 30 seconds.
 Start car and see if it's fixed.
 While performing egas adaptation you should be able to hear throttle body motor (based on your previous post you can hear it). If you don’t, keep cycling the key until you hear the motor on the throttle body engage. I have read where this has taken a few turns of the key for some reason.
				__________________Jäger
 300K Mile Club
