Thread: MAF or O2?
Old 07-19-2011, 04:03 PM   #15
Topless
Track rat
Topless's Avatar
Originally Posted by brian325is
Removing mass air flow requires a tamperproof t-20 torx bit.
Yes.
Or you can remove the torx screws with any common needle-nose pliars match them up to proper phillips head replacement screws, and then deposit the silly torx screws neatly in the trash where they belong. Some day my car will be completely torx free.
Note to OP: To test the MAF you don't need to remove it. Just disconnect the wire connector and drive the car.
