Old 07-19-2011, 11:38 AM   #2
pompous
Originally Posted by Lil bastard
Bad shifter switch.
Cheers!
This would be such a relief!
Is this what mounts to the side of the transmission the linkage attaches to? If so...the new(used) transmission that was installed already had a different one on it. So, the old one(switch) was removed with the old transmission and not reused.
I thought I read about this switch causing the car to not be able to shift in manual mode rather than automatic mode?? My trouble is automatic mode from 4th to 5th. Still the same culprit...the shifter switch?
"You finally got that Nazi-go-cart you always wanted." -Peer
http://i40.tinypic.com/ei6sns.jpg
pompous is offline   Reply With Quote
