just completed a drl install and used a great little device to
turn them on via wiring to the cars battery, another wire goes
into the sidelights and turns them back off again when the lights
are switched on, easy job !!!
http://www.amazon.co.uk/Time-Running-Light-Switch-Automatic/dp/B0045HYGZ4/ref=sr_1_1?ie=UTF8&qid=1311017090&sr=8-1
currently £18.99 delivered from amazon uk, saves alot of time and mesy wires all under the dashboard, it wires directly to the battery but for some strange reason only come on when the car has started.
Also just fitted mesh grills to the outer vents, another easy job with a bit of know how and a pop rivet gun !!
