Old 07-15-2011, 10:26 AM   #4
BYprodriver
BYprodriver's Avatar
Originally Posted by Paul
My 01 has been up on a lift for months, over the weekend I installed a used motor with lots of new parts. I'm at the point of trying to bolt up the black rear cross member that runs side to side underneath the the bell housing.
The bolt holes will not line up side to side, they are off by about 1/8".
What is the best way to pull in the attachment points?
If you just loosen the 2 rear suspension strut to frame bolts per side you can move them to lineup the bolt holes & then push them outward as much as possible to maximize rear track width & negative camber. No matter what you do you will need to check the rear alignment settings afterward.
