Motorsports AOS is designed for 2003 & newer Boxster as they have a newer version AOS. OK to block off AOS temporarily if it fails (I keep a plug in my console) but it will run rich as this is a large source of unmetered air the DME counts on. Also the vacum in the case helps the piston rings seal.
