Old 07-14-2011, 08:57 AM   #10
dja1980
Wow... some great information here... this forum is the best!
I'm not the original owner... bought the car with 25,000 miles in 2006. I racked up most of the miles cruising back and forth on the interstate when I was using it as a daily driver, but then got smart and bought a hybrid when gas got over $4/gal (the first time). The car didn't come with any service records, but I've got to believe the pads and rotors are original... all I know is that the front pads produce A LOT of dust!
I'm going to take a closer look at my rotors tonight to determine if the lip indicates replacement. If so, it looks like Pelican offers, OEM, Sebro, Balo, & Balo Coated. I'm guessing Sebro is what most of you use?
Also, do the vibration dampers come with the stock brakes... and if so are they reusable?
Overdrive... I like the idea of replacing the rotors every 3 sets of pads since this will save me a lot of money, but I believe I have more than a 1mm outer lip on my current rotors.
Pedro... I've used your site in the past... it's a great resource! Do new rotors come with the surface thicker than the lip? I'm almost positive a lip has formed on my rotors.
WhipE350... thanks for the offer. If I'm going to do the job, I'd REALLY like to spend the additional money to get away from dust. I'm sure someone else will take you up on free pads though!
dja1980 is offline   Reply With Quote
