Thread: Sensor Codes
Old 07-14-2011, 05:50 AM   #2
keithl
Originally Posted by Jager
When you remove the oil fill cap while the car is running (eninge needs to be warm) the idle will increase a little if your AOS is good. It might idle a little rough but idle RPM's should go up a little. If the idle drops and runs real rough (almost stalls) you have a bad AOS. Was the cap hard to remove due to a lot of vacuum?
Cap easy to remove and the RPM's increase, so I guess the AOS is good. Oh well.
Thanks for the suggestion.
keithl is offline   Reply With Quote
