In my somewhat limited experience with oil + coolant, they don't blend together smoothly because coolant = water based and oil = oil based. There's no emulsion.
Though it'll look like chocolate milk, it won't be a smooth even consistency and you'll see oil seperation. I can't see any in that photo.
Though you certainly could have an issue with oil getting in your coolant, it seems odd that you JUST CHANGED YOUR COOLANT with non-porsche-approved version and now this happens. If you didn't notice abnormal coloring in the coolant when it came out, then it would be odd to suddenly be down 2 quarts of oil due to it being leached into the cooling system (which, by the way, would be over-flowing if it absorbed 2 quarts of oil).
I could be missing alot of info, but I'm guessing the following:
1. The photo is distorting the look of the coolant a bit.
2. You mixed two coolants together and they created that color and density and are in the early stages of gelling.
Let the mechanic look of course - but this is my guess.
99 Boxster 5spd - 64k miles
06 Civic SI - 114k miles, D.D., unbelievably reliable and fun to beat on everyday.
08 Legacy GT 5spd - 74k miles.
