Originally Posted by Jager
Since you have alarms on both sides "lean mixture threshold" I'm thinking vacuum leak. Have you ever replaced your Air Oil Seperator?
No I haven't replaced the AOS. I did the Cap "test" and it seem fine, also, the car ran rough with the cap off and clear up with it back on, not getting a lot Of smoke, maybe a little smoke on startup a couple of times a month. So you think it
Could be something other then the O2 sensors? Thanks.
