Thread: Track helmet
Old 07-12-2011, 10:16 AM   #1
Topless
Track rat
Topless's Avatar
Originally Posted by jaykay
I was considering not worrying about Hans as the helmet may likely expire before I am racing. This would open up the field to motorcycle helmets....Do you feel that Hans will be mandatory for all track exposure soon
No. Just a personal safety consideration. If you use a 5/6 point harness, you probably also need a HANS to protect your neck (see Dale Earnhart Sr.). With a harness your torso is effectively locked in place and your neck becomes the weakest link by far in a crash. If you still run stock 3pt belts, your torso is allowed some movement which actually protects your neck somewhat. Active airbags also contribute to neck/head protection.
