Old 07-09-2011, 08:51 AM   #7
Jager
Jager's Avatar
Originally Posted by BobX
Thanks for the suggestion, Paul. I tried what you posted and after sitting for several minutes (4 to 5) I never heard the throttle motor. I'm guessing your suggestion has something to do with the electronic throttle control and learning minimum position (accelerator pedal or throttle blade?). Regardless, I tried a couple times and could not fix it. Any other suggestions would be appreciated. I even tried disconnecting the battery for several hours. Thanks.
While performing the adaptation, keep cycling the key until you hear the motor on the Throttle Body engage (you should be able to hear the motor on the Throttle Body). I have read where this has taken a few turns of the key for some reason. Leave the key on for one minute, then turn the key off and remove from the ignition.
Jäger
300K Mile Club
Jager is online now   Reply With Quote
