Old 07-05-2011, 11:58 AM   #177
Bobiam
Bobiam's Avatar
J. Tinsby said...."Whoever at Porsche thought that sealing grease in a bearing and then immersing it in hot engine oil and expecting the grease to stay IN needs to seek help. Too bad no class action suit was ever started when the problem first appeared."
Does sort of make me loose faith in their vast engineering knowledge and big R&D budget. Think about it.....They put a bearing inside of an engine that could easily deliver continuous lubrication to it, but choose to put seals on it and give it a few drops of grease to last it the car's lifetime. Yeah, ya can do this with a water pump.....but not an intermediate shaft that handles the timing chain!!!!!! The warrantee on this item should have been extended to 100,000 miles. Not all of their customers can afford to throw away a car worth $10,000-30,000. Porsche couldn't even create the fix that aftermarket shops did! But that would require admitting that they designed a time bomb defect into the motor.
2001 Boxster, GT3 console delete, lower stress bar, RoW M030 suspension package, painted bumperettes.
Bobiam is offline   Reply With Quote
