Old 07-04-2011, 06:19 AM   #13
Stroked & Blown
Originally Posted by blue2000s
"The clutch sits in between the transmission and engine. It's bolted to the flywheel, and the flywheel is bolted to the crankshaft. Each time the clutch pedal is pushed in, the throw-out bearing pushes an amount of force on the pressure plate to dis-engage the clutch. This force applied to the pressure plate obviously puts an amount of force on the crankshaft."
"when starting the engine with the clutch pedal down, it's putting amount of force on the crank, and since the engine was off, there has not been any oil flow or oil pressure at all, possibly resulting in excessive wear on the thrust bearing. "
From: http://www.dsmtuners.com/forums/articles-engine-fuel/342560-crankwalk-depth-explanation.html
Ah, lateral crankshaft bearing load from the TO. Makes sense. Thanks for the clarification.
98 Arena Red 986
Stroked & Blown is offline   Reply With Quote
