P1502 Pending
Finally got a code reader hooked up and saw a P1502 Pending. When I clear codes while the vehicle is running, the car runs like there is nothing wrong. Reading codes after clear codes, there are no faults active or pending. But on the following start, it will go back into reduced power mode and have P1502 Pending. Based on what I've learned so far, it won't learn "egas" and it is failing some throttle code during key up. However, I think it's failing falsely as once the code is cleared, the vehicle runs flawlessly. Not really sure what to do at this point. And thanks for the followup, Paul.
Any help would be appreciated.
Robert
