Old 07-01-2011, 07:11 PM   #17
jhandy
If you think that the cylinder three is lean and this is causing a misfire, then I would move to injector plugged up, valves not working right... I say this because I do not think that the DME controls mix rates per cylinder, rather by bank 1 or two. Picking up values from the 02 sensors.
Look at the most common and reasonable things first. Look at the wire or connection. Move coil pack to another bank, rather than another cylinder on the same bank.
2002 S
jhandy is offline   Reply With Quote
