Old 07-01-2011, 04:01 PM   #15
sparker
I'm actually leaning towards an intake leak at the moment causing cylinder three to run lean and misfire. The other cylinders probably would error too if I went further.
Just think there must be a reason for my wideband to read so lean on that right hand side bank. Lack of spark would make it run rich.
That being said, I will still inspect the wires to that coil in case it is the issue. Will also look at I injector wires to cylinder 3.
Sam
sparker is offline   Reply With Quote
