Old 06-30-2011, 09:35 PM   #3
jhandy
The C code is going to be a little harder to crack. Someone here that has a Porsche OBD service manual that can look it up.
But basically it is a error with something that gets input from the chassis. In my limited experience it is commonly the ABS system.
with the boxster, it does not have traction control, no roll sensor, manual trans. there really not many other choices aside from temp sensors, and speed sensors.
Also it could be a non USA code, in which case, the Piwis manual will tell us the code.
Porsche tech guys usually gaurd this book like it is the bible and it is not easily had.
2002 S
jhandy is offline   Reply With Quote
