Old 06-30-2011, 04:04 AM   #10
fooksm
Another update
I have just been out to compare the rear-end of this Boxster with another which I have sitting here and see that on this Boxster, the handbrake cable sits below one of the suspension arms, whereas on the other Boxster, the handbrake cables run over the same arm, towards the front of the car.
The White Boxster Handbrake attachment clearly shows the cable running under the arm, under tension and the blue boxster handbrake image clearly shows it running over the same arm.
Could someone please just confirm that the cable runs over the arm on their boxster?
The engine specialist took the engine and gearbox out from underneath the car when they did the work, so it would seem to me that this could have been the time when the handbrake cable moved from above the arm to under.
fooksm is offline   Reply With Quote
