Fantastic! I sprayed the WD40 in the rubber and the problem was rectified in seconds! (I also sprayed the door hinges a lil to make them less noisy) so strange how it initially sounds as if the creaking noise is coming from the suspension.
I also managed to stop the heat shield which was wrapped around the pipe of the exhaust from rattling on startup. happy with my Boxster again
Thank you
Craig
