correct. i believe technically the cut off was for MY 2006, but those engines were used in some MY 05 cars. prior to that you could replace the bearing by extracting it. after that you must tear down the engine and ship off the entire shaft since there is no way to remove just the bearing. all engines with an IMS bearing have the potential for failure. just different ways to resolve them.
from LN Engineering's site:
Can I replace my IMS bearing?
LN Engineering offers three IMS solutions, two of which can be done without disassembly of the engine while the engine is still in the car:
single row IMS retrofit kit (fits MY02-05 M96 engines including some MY00-01)
dual row IMS retrofit kit (fits MY97-99 M96 engines including some MY00-01)
The last option, our IMS Upgrade, requires engine disassembly. The intermediate shaft must be sent in to us to be upgraded to our triple-bearing upgrade. A separate ceramic hybrid bearing upgrade is available for the late-style MY06-08 M97 IMS as well.
But before proceeding with an IMS Retrofit, you first need to identify which IMS you have!
How do I know which IMS my engine has and what can I do?
As long as the engine in your vehicle is original to the car, you can expect to find the following:
All MY97-99 vehicles with their original engines will require a dual row retrofit kit.
MY00-01 vehicles may need either a dual row or single row retrofit kit, so you'll need to inspect the flange, as shown below to be sure which will be needed.
MY02-05 will need a single row retrofit kit, although depending on how late the build date was, there may be some MY05 vehicles with the updated M97 IMS, which is not serviceable, at least without teardown of the engine.
If your vehicle has a replacement engine, expect to find the prevailing bearing used by Porsche in those years. If the engine was made for MY06 or later, it will have the late revision, larger IMS bearing which is not serviceable.
