Old 06-27-2011, 06:36 AM   #2
Stroked & Blown
Originally Posted by RandallNeighbour
What you didn't share above was if there was anything actually dragging on the ground under your car. I would assume from the question that there wasn't anything.
I'd definitely get it towed to a shop if you can't see anything external causing the noise. If you're up for it, you can pull the carpet and aluminum shield off the firewall between the seats and motor and have a look at the belt and pulleys...
It's hard to tell you what's going on without being there to hear it. Don't fret about the "what if's" of something catastrophic just yet. Let a mechanic tell you for a fact what is creating the noises.
Thanks for the input, Randall.
Yes, I got on the ground and looked under the car from the front, middle, and back. Nothing under there.
98 Arena Red 986
Stroked & Blown is offline   Reply With Quote
