HELP! Boxster won't turn after starter cleaning!
Ok guys, I've had the annoying chirp of the starter not disengagning for the past few weeks. After doing a little searching on here I decided to go ahead and clean and lube it.
Taking everything off was pretty easy and straight forward, got to the starter blah blah blah cleaned it and lubed it with White Lithium and some Slick 50 One lube. Everything went back together smoothly and everything was accounted for (that I know of). I did have an issue putting the intake back on, tricky bastard. So before buttoning everytyhing back up I just wanted to make sure it started.
Nothing. I turn the key, all electronics come on, try to turn it over and there is no sound or anything. Back off the key and try again and then it locks up. I can no longer go to the start position, but can still turn on electronics. If I take the key out, it again gives me 1 try to start and then locks the start position back up.
Any advice here?
I still have the car taken apart, top off, firewall behind the seats ect, and the intake (like I said I'm having signigicant trouble getting it back on). Is there anything I'm missing? Only thing engine wise I don't have on is the intake tubing
Help me please! All dealerships are closed on Sundays obviously so I have no one to call
Thanks guys!
