Thread
Successful rear wheel bearing change...kind of
06-26-2011, 10:53 AM
2
seventythree
Go back and double check the way you have reassembled the emergency brake. You may have installed the brake shoes upside down.
No need to press in the ball joint taper pin. The nut will pull it in tight enough.
seventythree
Find More Posts by seventythree
