Old 06-25-2011, 11:45 PM   #1
Gforrest2
Gforrest2's Avatar
Left turn signal not working
Once again I'm far away from home and have developed a problem. Left turn signal does not work. Right is fine and all four blink when the hazard is on. Did a search here and a general search but could not find anything. Couldn't be fuse could it? I suspect a problem with the stalk and assume working on the column is not DIY.
Edit: Seems to be an intermittent problem (don't you just love those). When you first start the car up, it works once or twice, then stops. The next time you start it up, same story.
Glen
Gforrest2 is offline   Reply With Quote
