I have never used the jack that came with the car; I always use a floor jack and stands. For the AOS project you should use at least two stands at the rear lift points to keep the car stable. If you are going to maintain your 986 regularly you will want a nice floor jack and four stands. A car lift would be nice but depending on the design can limit access to some things on the vehicle.
