Old 06-22-2011, 10:53 AM   #2
jhandy
check Fuse B1 - brake light
B7, B8 - tip control- may also be involved
There should be a manual override button somewhere so you can shift.
Used when you need to shift into neutral and your battery is dead or the car is not running.
Also I believe that you have two switches on the brake pedal, one for brake light, the other for the trans unlock.
bypass them to see if that fixes it if the fuses are ok.
the switch is cheap, like 18$
99661311302
99661311001
2002 S
jhandy is offline   Reply With Quote
