Old 06-22-2011, 08:09 AM   #1
jhandy
If you hooked up one of those real time DME readers you will be supprised. The actual temp will go to around 235ish, if your fans are on high up front, then you are close, I think they turn on at 210.
Quick cheap thing you can do that works is Redline Water Wetter. 10$ at autoparts store. Worked great for me.
Also if not already done, remove bumper and clean the rads up front, lossen the front ones, and clean inbetween.
You can get a Radiator comb from autoparts store, 5$, it will fix all of the messed up fins that you have.
2002 S
jhandy is offline   Reply With Quote
