Old 06-21-2011, 04:25 PM   #3
Jager
Jager's Avatar
Originally Posted by ASpec818
how much to replace the bearing?
The bearing itself is ~$600 and normally you would replace the clutch, RMS, and possibly the flywheel since you are in there. Parts a labor add up, but if you do it yourself you can save a lot of money (if you have the tools). You will need the special tools to remove and replace the bearing (a couple hundred more $$) plus other tools (as I learned about the triple square socket). Plus oil, filter, might as well change the transmission oil since you're under there too.
Jager
