Old 06-21-2011, 11:00 AM   #7
jhandy
some micro switch is not working.
both trunks, doors, and glove box thing
if it is the doors, then the lights will stay on inside when the door is shut. If it is the trunks then the dash board indicator will be on. So i am guessing it is the glove box.
Take the lock apart and you will see the wires. manually connect the wires to see if that stops it.
2002 S
jhandy is offline   Reply With Quote
